I have a small oil drip at the left rear corner under the radiator area . The drip looks like auto trans oil and all I can see when I look under is where the leak has run down on what I think is the l...
Thanks Bret and Dennis and I will check the fittings in fact on my old ford pick-up I had the lines break inside the radiator and my C-6 transmission was ruined. What is the second radiator, is that called the inter-cooler and what does it do and what runs through it. The leak seems to be coming from up higher on the radiators.
