YDORNMT
Nov 11, 2022Explorer
Well usually it goes up and then right back down. When I posted, I had just checked all the fluids (I'm pretty sure there is way too much water in it though, I'll make a different post about that) and it ran fine. I parked it overnight, went to move it the following morning, and instead of gauge going back down to 40ish, it stayed maxed out.
I will see what I can do about checking the possible situations y'all gave me.
I turned it off, on, off on, off, and then the third time I turned it back on the gauge read as normal. So I bet you're right about what it is. Sounds right anyhow.
38,778 PostsLatest Activity: Jun 10, 2026
