udidwht
Nov 12, 2022Explorer
You either have a flakey oil sender or your relay is acting up. The relay under the doghouse hung on the inside up against where your accelerator pedal is at. I'd replace the relay first.
I'd get a can of electrical contact cleaner and spray the connector end on the switch till clean.
38,778 PostsLatest Activity: Jun 10, 2026
