wildmanbaker
Nov 13, 2022Explorer
When all these ideas do not fix the problem, it may be time to look at the oil pump bypass. Your description sounds like the bypass valve is hanging open then it is first started. It could be hanging closed because of wear, or debris in the system not allowing the valve to open. Good luck fixing your oil pressure problem.
38,778 PostsLatest Activity: Jun 10, 2026
