becker's avatar
becker
Oil stick problem - need help
My coach is a Monaco Dynasty 2008 with a Cummins 450 diesel.... when I check the oil to see if it needs any, etc., I can't it the dipstick to go all the way back in..... it lacks about an inch from going in all the way to where it should go in (I hope I am communicating properly.... I jiggle it (this last time) for about 20 minutes and the dipstick will not go in all of the way..... in the past when it will not go in all of the way, I jiggle it for about 5 minutes and then it goes in all of the way..... it feels like it is hitting something in the interior of the motor..... has anyone had this same problem and how did you remedy it.... I need help.
Thanks
Becker
  • has the cap on the dip stick come loose and you have bottom out the stick in the engine.
  • I have the same problem. I have to pull it out and turn it slightly, often repeatedly, until it “seats” properly. Gee, I hope this post gets past the censors.
