mtrumpet's avatar
mtrumpet
OK to mix tire brands? (Front/Steer tires)
Never did I think that I would have a tire question, but I do. I did an extensive search through the many past tire posts, but could not find an answer to my question..
Is it ok to mix different brands of tires on the front (steer) provided that they are of the same size and load rating? For example, A Goodyear on the drivers side and say, a Hankook or any other brand on the passenger side if both are 275/70R22.5 Load Range H ?
I don't see a problem, but is there something that I may not be considering?
I realize that this is a no-no with the rear duals on the same side.
  • We are mixed front to rear...
    I'm not sure I would mix on the same axle.
    Just me I guess.
  • It may make a slight change in handling if there is any difference in the tread height between the two tires. Definitely don't want to do that on a dually configuration.
