dgtjhatt
Jul 22, 2018Explorer
Old Gasoline
We are about to buy a class c that has a Ford V-10. this unit is a 2008 with only 8000 miles on it, but has been setting in a building for 3 years with a full tank of gasoline. The engine starts and r...
suprz wrote:
I would agree with those who said run it, and refill with seafoam. I would be more concerned about the carb on the generator though. That will more than likely need a cleaning. Start it up, and let it idle and get up to operating temp, and while that is going on, check other things like brake lines, tires for cracking, look for leaks in the cooling system, make sure the engine doesnt over heat due to stuck thermostat... Lots of things to check on a coack that has been sitting for that long when you dont have the full picture of what was done before it was parked
