turbojimmy
Jun 01, 2014Explorer
Old-style gray water valve - parts source?
So I was closing my gray water valve and suddenly it got really easy to turn. Something obviously broke inside it. It's mostly closed, with a little bit of water running out, and will now neither close all the way nor open up again. The knob just spins and spins. Which is a good segue to my question: are parts available for these old, spigot-type valves? The black tank is the standard cutter-type valve. I'm afraid I may have to replace both valves which would be a hassle. If I could get parts for the existing valve (I suspect the stem snapped inside) that would be best.
A google search only has yielded the newer-style valve assemblies with cutter-type valves on both black and gray feeds.
