cjd10 wrote:
Getting ready to pull the trigger and purchase new MH with 50 amp service. We usually stay in older state park campgrounds that only have 30 and 15 amp service. My current MH has 30 amp plug and prior owner added rear air conditioner that has its own 30 amp plug so it was easy to use an adaptor on one and be able to run both ac's.
Question is how are those of you with 50 amp rigs plugging in? Adaptor to 30 amp? If so doesn't seem like you would be able to run both ac's. Have looked at 50 amp splitters but not sure if that will solve my issue? Thought about having dealer put that rear AC on its own plug before taking delivery. Living in the South being able to run both ac's is a must.
Thanks for any advice
I installed a dual power adapter that splits my rear A/C circuit so that I have the option of running it on it's own 20amp circuit and do so quite frequently. I suggest you do the same, so as to keep it isolated from the rest of the coach.
