mockturtle
Aug 26, 2013Explorer II
fighterpilota wrote:
Born free are nice looking. All fiberglass. Do you have to worry about blisters in the fiberglass developing like they do on boats? Do they have any issues with leaks or are they essentially built as just three pieces? I could get along with the 26 model with the rear corner bed even though it doesn't have the booth dinette. Thanks for the suggestion.
Bought mine used in 2009 in AZ. There are some slight ripples on the side from heat warp but, because the sidewalls are not laminated, there is no 'delamination'. I had a leak in the front cabover window. It didn't leak to the interior walls but into the fiberglass cabover. No permanent damage and, though the fix was rather expensive, it was worth it. Also had a slight leak in an outside compartment that stained a bit of the carpet inside the compartment. Regardless of these issues, Born Free is a very well built motorhome and I would buy another one.
38,766 PostsLatest Activity: Jan 10, 2026
