We Cant Wait wrote:
Recheck with a multimeter your added charging wire to ensure that it is getting proper voltage (13+ volts) from the coach charging system. This wire should be more then enough to keep the battery charged.
X2 The charging line should provide enough for any need.
Maybe you have the sensitivity set too high on the Rvi braking system.
Hope you aren't using the Rvi charging system. I tried it and had several problems with it. A few times battery ran down. Once it burnt charge line near MH hook up.
I took it off and just ran a 10G 20AMP fused charge line from the house batteries to the car battery. I haven't had a problem since with a dead toad battery.
To tow a 2012
Four-wheel drive (4WD) vehicles can be towed with all four wheels
on the ground or with all four wheels off the ground using a vehicle
transport trailer. Do not tow your 4WD vehicle with the front
wheels off the ground (by using a tow dolly) and the rear wheels
on the ground; this will cause damage to your 4WD system. If you
are using a vehicle transport trailer, follow the instruction specified by
the equipment provider. If you are towing with all four wheels on the
ground, refer to the towing instructions found at the end of this section.
If you tow your vehicle with all four wheels on the ground:
• Tow only in the forward direction.
• Release the parking brake.
• Place the transmission shift lever in N (Neutral).
• Place the ignition in the accessory position (refer to Starting in the Driving chapter).
• Do not exceed 65 mph (105 km/h)
• Start the engine and allow it to run for five minutes at the beginning of each day and every six hours thereafter. With the engine running and your foot on the brake, shift into D (Drive) and then into R(Reverse) before shifting back into N (Neutral).
