Executive45
Jan 25, 2015Explorer III
David, as Johnny T suggested, push both arrow keys at the same time. Doing so, will place the transmission in a search mode. You'll see the keypad flash then it will display d 1 followed by a code. Write down that code and press the "mode" key. You may see D 2 followed by another code. Write that one down too. Continue to press the "mode" key and write down any other codes that appear. Make sure the key is in the ON position. Return and post the codes you've discovered and maybe we can help you.
It sucks to be on the side of the road, so we feel your pain...Dennis
38,769 PostsLatest Activity: Mar 31, 2026
