Mr_Mark1
Jan 25, 2015Explorer
David0725 wrote:
My DP. DONT SEEM DP HAS much power the shifter pad is fashing 6 6. boost gage is bouncing around. can use help
plese
David, I'm just going to throw this out as I read it on another site. A guy was talking about his low boost and it was the CAC (Charge Air Cooler) radiator that is front of the regular radiator. Assuming all diesels have this.
They develop leaks that you can check with a bottle of soapy water. They say concentrate on the lower corners to see if yours is blowing bubbles.
Good luck and CAC's are not cheap.
MM.
38,769 PostsLatest Activity: Mar 31, 2026
