larrylwill's avatar
larrylwill
Onan 2600 generator
My 08 Roadtrek has a Gen with 71 hours on it. In Dec we ran it for about 4-5 hours to keep warm coming back from Fla. Since then I have run it every month for an hour or so. Today I started it and turned on the AC and it ran about 10 minuets normally then started to surge then shut off. I found it was low on oil. So I filled it up and it again ran for about 10 minuets then surged a few times then stopped.
It will start ok but only run about 10 minuets then stop, it doesn't surge so much anymore it just stops. I tried loosing the gas cap, didn't help. I will replace the fuel filter in a day or 2 and try running some seafoam through it. Any other Ideas?
  • You should run it at least 2 hrs a month (continuously) at 1/2 to full load. Best guess is the carb is gummed up. The Seafoam may fix it. The carbs can't be rebuilt, and you will have to pull the gen-set to replace it.
    Also, use a Kill-a-watt meter to check volts, and make sure the frequency is at 60Hz.
    It may just be running too slow, so is stalling when it gets a little load. There is a screw adjustment on the carb linkage to speed up, or slow down the gen-set.
    Make sure the altitude adjuster is set correctly.
