Bordercollie
Oct 31, 2014Explorer
Mine does not always start from the panel inside the rig if generator has not been run recently. If I run the chassis engine and then hit the inside generator start button, the genset will usually start probably because the generator is connected to the engine starting battery and it is getting 14+volts from the engine's alternator I suspect that there is a voltage drop in the wiring from the panel to the starting battery and RV generator's starter. Hope somebody with knowledge of this chimes in on what to do about it.
38,706 PostsLatest Activity: Jan 31, 2025
