DaCrema
Aug 25, 2015Explorer
If the generator ran fine prior to this and all of a sudden quit I would start by doing the simple things. The sea foam was a good start.
I would also consider the fuel filter replacement already suggested.
Have you check fuel flow by disconnecting the line from the carb and running RV? It should run long enough on the fuel in the float bowl to do the test.
The issue on my 2007 RV was the fuel pump. The replacement is involved but not that hard. Likely to cost less than a carb.
