Jerry_Amerson1
Aug 27, 2015Explorer
It looks like I can get to the first two bolts holding the carb pretty easy, but I suspect there is a third around the back that may cause some problems. The fuel line looks easy as it's right in front. I really don't see anything else except the choke linkage and it's in back so I will need to get the carb loose before I can get to that.
Has anyone ever pulled one of these carbs off with the generator still mounted in the coach, or should I go ahead and put a jack under it and drop it down.
Also, where is going to be the best place to get a new or rebuilt carb.
Thanks again for all your help.
Jake
Jake
