j-d
Aug 27, 2015Explorer II
You said ONAN 4000. Is the model number "4KY?" If so, I summarized carb removal above. You need to flex the blower housing a little. That's what the Torx T-30 screws are about. Then there's only 2 bolts, 1-mm hex heads, holding the carb and they're accessed after the air filter is off. No need to drop a 4KY to remove the carburetor.
If Model is NOT 4KY, then what is it, please...
