Jerry_Amerson1
Aug 27, 2015Explorer
I don't think it's the 4KY model. Mine has Onan 4000 GenSet as the model number.
It looks like dropping the unit is not what I want to do. If I can get to the fuel filter to change it out and then drop the bowl on the carb and clean it with cleaner that might do the trick.
The fuel filter looks to be down flat on the bottom panel at the rear of the unit, but I don't see any way to get to it so any suggestions would be appreciated. Also, there is a nut on the bottom of the carb bowl, so if I take it off can I just pull the bowl down and out for cleaning purposes.
Thanks again for your help.
Jake
Jake
38,782 PostsLatest Activity: Sep 10, 2026
