Jerry_Amerson1
Aug 27, 2015Explorer
Yes, that's it exactly. The fuel pump and filter is over on the right at the bottom of the unit.
I know it has been changed because I have two receipts from Camper World where they changed it. It looks like they pulled a cover plate up and away far enough to pump mounting bolt, and it looks like there is only one. Then the connection to the fuel line is the next thing to undo, then I think they have put extra hose on the pump/filter so it can be pulled out of the unit before disconnecting the incoming line. I will also have to track down the hot lead on the pump so I can change it out as well.
Any help here would be greatly appreciated, and can you tell if that bowl on the carb comes off with the nut that's on the bottom of it.
Thanks again
Jake
Thanks again
Jake
