Oldme
Aug 27, 2015Explorer
If you are able to keep it running by blocking the CHOKE OPEN then the choke is set too tight or ypu have a mechanical spring/lenkage problem. Just like cars of old you would need the choke to close more in colder weather than hot.
On the generator you will see an altitude setting screw. This does basically the same thing. Air is thinner at high altitudes.So you do not need the same amount of choke as at sea level.
Now you have have a problem with it either being set for the wrong altitude or
the spring/linkage that should allow the coke to open is stuck or something is broken. If the spring is broken then the air entering the carb will pull the choke closed and choke out the motor.
When ypu block it open, you are keeping the air entering the carb from pulling the choke closed.
38,782 PostsLatest Activity: Sep 10, 2026
