azrving
Jun 28, 2016Explorer
Good points so far. If the relay does respond to tapping it could be that the contact tips are worn or the connector plug is dirty. You could also check the oil pressure shut down switch and check all the connections or circuit board connectors. Sometimes removing and replacing a connector will establish a good connection. Do one thing at a time and check results.
38,769 PostsLatest Activity: Apr 03, 2026
