- bounder39zmanExplorer IISince you have a 5.5BGM (older style Marquis set), adjusting valve lash is a bit trickier. You will need to remove intake and exhaust manifolds, then tappet chamber cover plates to access tappets. Valve lash is .005" intake and .013"ehhaust. You will need 2 intake manifold gaskets and 2 exhaust manifold gaskets, plus 2 or 3 tappet chamber gaskets. The valve lash is adjusted at the tappets on this "flathead" style engine. Your ticking noise is possibly caused by excessive valve lash, could also be excessive carbon build up in combustion chambers, in which case you will need to remove cylinder heads and clean carbon from heads and pistons. Sometimes a can of Sea-Foam aerosol sprayed into carb can remove some carbon, but is only temporary fix. Good luck
- jyrostngExplorer
GREGORYJ wrote:
Yes, it is easy to do. You need to take off the head rocker covers so I suggest picking up 2 rocker cover gaskets as the old ones will probably tear when removing rocker covers. The valve lash gap is .oo4" with engine at room temperature.
See manual : https://www.manualslib.com/manual/822463/Onan-Hgjab.html
Thank You - GREGORYJExplorerYes, it is easy to do. You need to take off the head rocker covers so I suggest picking up 2 rocker cover gaskets as the old ones will probably tear when removing rocker covers. The valve lash gap is .oo4" with engine at room temperature.
38,782 PostsLatest Activity: Aug 30, 2026
