novi2some wrote:
My fuel tank is full. If I add seafoam to the gas tank on the motor home, will this help to get the fuel to the generator? with an 80 gallon tank, how much seafoam do I add? To get to the carb, do I remove the plate on the bottom of the generator?
Since it's now obvious you have not worked on this or other mechanical items it's time to take your MH to someone who knows what they are doing. In the long run it will save you money and time. If you have the manuals to your MH and the genny, I'd suggest you read them and understand how things work.
I've laid out a step by step process for you to troubleshoot this problem which would have led to either fuel, fuel line, or carb issues. Placing seafoam in your tank will only help after the problem has been resolved.
-paul
