my generator will no start . started acting strange. only ace would work no power any where else and now will no start longer than 2 sec not gas problem code 32
IIRC Onan Had a problem back in 02 - 03 with a diode failing in the control board.
I did find a service bulletin that ma apply to your situation http://ww2.justanswer.com/uploads/HankF/2010-04-12_022526_PSB_676_-_Code_32.pdf and the answer I also just found http://www.justanswer.com/small-engine/3dcby-onan-5500-generator-starts-stops-giving-service-code.html
