my generator will no start . started acting strange. only ace would work no power any where else and now will no start longer than 2 sec not gas problem code 32
Before you tear it all apart. I have found many Onans to have a fuel problem and show other faults. Make sure it is getting fuel and the filter isn't plugged. Make sure it is getting fuel by pulling the return line if you can and see if fuel is flowing thru it. Mine has done it 3 different times. Then go with the diode.
