my generator will no start . started acting strange. only ace would work no power any where else and now will no start longer than 2 sec not gas problem code 32
The two c/b's on generator are only ones on genset. You should check wiring at transfer switch or possibly bad contactor/relay in transfer switch. look for loose wire connection at back of breakers at gen. Since a/c 's are working, problem is likely not in generator. Also make sure GFCI outlets have not tripped, causing outlets to not have power
