2Bargos
Nov 22, 2014Explorer
I had same problem on my coach, sometime the generator would run good other times not.
Long story short,The fuel supply line coming from tank had a crack in it and would cause the fuel pump on generator to "lose its prime"by allowing air in line.
You mentioned the unit would run fine while pulling gas from another source so it has to be one of two things, a hole in fuel line or something wrong with gas pickup in tank.
