rgatijnet1
Nov 23, 2014Explorer III
Is the vent on your fuel tank plugged? Some gas caps are vented and if the vent is clogged, the generator fuel pump may not be strong enough to overcome the vacuum. An indication of this is that the generator will run for less time when your main fuel tank is full and will run longer when the fuel level is lower in the tank. Just take the fuel fill cap off and see how the generator runs.
