swreeder70's avatar
swreeder70
Onan 5500 No Gas in Winnebao Adventurer
I have a 2007 37b Winnebago Adventurer that has been having intermittent generator problems on and off for the past year.
Each time it acts up, the fuel pump is chattering and there is no fuel getting to the carburetor.
IT IS NOT a LOW fuel in the tank issue!!
It has at times just started working on its own. This week, it failed and I cannot figure it out. I have replaced the fuel pump, the fuel lines, the fuel filters and still no gas.
If I run a line right from the pump into a gas can, it will run like a champ. I can suck gas out of the tank through the line (YUCK)!!
We leave for a week long trip tomorrow and I'm out of ideas.
Any suggestions on what else to try?
  • Sounds like it may be a bad or dirty fuel pickup in the main fuel tank itself. It is different than the vehicle pickup, it is mounted above the 1/4 tank of fuel level. You do have more than 1/4 tank of gas.
    Easier try for a fix would be to blow air through the generator fuel line into the tank, this might clear any obstruction. If this doesn't work, you may have to drop the fuel tank to find the problem.
    Since the genset works through a line to an external gas tank, the problem is not with the genset.
    Ken
  • Have you tried staring the genset at the unit itself? If yes, have you disconnected the remote cable? It is possible that the "front" switch is bad.
  • If the genset had been sitting for a long time, the old fuel can varnish the carb bowl and cause symptoms like that. Read an article in the latest FMCA magazine today about it online. Haven't gotten that issue in the mail yet. The author had to replace the carb in that case. I know generators like to be used.
