tropical36
Jul 12, 2016Explorer II
11178adm wrote:
check the voltage at the gen set starter solenoid or if it has one the relay that activates the solenoid. should be 12 volts, also check the voltage at the trigger post when trying to start the gen set does it start with the override that connects it with the house batteries? also my 94 am eagle has it's own battery and alternator.
Problem solved above, but good to know and did try the aux. boost along the way.
Interesting that your Eagle has it's own of everything. What brand of gen set is it?
