Roman_Duck's avatar
Roman_Duck
Onan 7.5 quiet run diesel filters
Hello to all,
I have an Onan 7.5 genny model 7.5HDKAJ11451D.
I've been able to cross reference the oil filter to napa part number but unable to verify the fuel& air filter numbers. Can anyone help, either the onan part number or a napa filter number would be helpful
Listed below are filter numbers that I believe to be correct.
If you have filter numbers for this in another brand that also would be helpful etc.
Thanks for your help
Oil filter Onan part# 122-0833 napa gold 1064
Air filter onan part# 140-2897
Fuel filter onan part# 149 2513
  • Hint. If you don't have line wrenches, get a set. You do not want to round over the fuel line nuts.
  • Watch this video on changing oil on your 7500 quiet diesel.
    https://www.youtube.com/watch?v=CxqkHAAH818
    Bill
  • Roman Duck wrote:
    Thanks for the confirmations on part numbers.
    First time servicing it since purchase, as far as mess goes, the DW says that I'm a magnet, now I'll be an oily magnet.
    Actually if you have any suggestions, beside having it done by others It would be grateful. Our last genny was a emerald series, pretty simple to service. From what I've read it appears that the fuel filter is located close to drain plug for the engine oil.
    Otherwise i'm open to help
  • Thanks for the confirmations on part numbers.
  • Oil and air filter part numbers are correct. I could not find the fuel filter listed on the web.
    www.cumminsonanstore.com
