I did get the capacity from the panel. I did not get 4.5 quarts from the drain. This could because the overflow tank was clogged and not sending extar fluid to the radiator. It has been cleaned and there is now flow. I bought this coach in Jan. of this year. It seems there may have been some neglect on maintenance. I left the cap open overnight hoping it would burp out any air bubbles but it didn't seem to do much. I will probably take a lazer temp of the engine before changing out the high temp sensor or thermostat the water pump and belt seem to be in good shape. I was hoping someone was very familar with this engine and could let me know the best way to remove air pockets
