JimM68
May 14, 2015Explorer
36 is a phantom error code, 'rpm dropped below 1000 for no reason"
Most of the causes listed indicate a fuel supply problem.
run the genny with an external fuel source to rule out any internal problems.
Check and or replace any annd all fuel filters and rubber fuel lines between the genny and the coaches tank
It is very possible, even likely, that the problem is cause by an invisibly separated or collapsed rubber fuel line, or a hoole that is allowing the genny to suck air.
