TragedyTrousers wrote:
I was thinking about buying a EC30W but have some concerns of using it. I have hit the prime button on my Onan generator before I start it. Does the EC30W have the ability to initiate priming the Generator before starting? Also what happens if the Generator doesn't start right away. Will the autostart feature continue trying to start the Generator running the battery down?
The manual says the EC30W will attempt to start the generator for approximately 30 seconds. If it does not start it will wait 30 seconds and try again. It will only do this 3 times.
I am using this mainly for the air conditioners if shore power fails for some reason. I will always start the generator before we leave to make sure it is primed and warmed up and then shut it down in case the auto start is needed.
I do the same thing with my boat motor before I take it to the landing.
