Can you change the fuel filter in an onan microquiet 4000 generator from the bottom or do you have to remove the solenoid and control module to get to the hose clamp?
We have the Microquite 4000 generator. As I have posted a time or two, I added a switch to turn off the fuel pump and let it run out of gas, I have not seen a fault code from doing this.
