I have a 2001 Winnebago Adventurer. My gen cut off while in use driving. It cranks but will not start. Watched the green light flash code 33. Anyone know what that is and how to repair? Thanks NY...
Google Onan 5500 generator code 33. You will get info about reading the codes to make sure you are getting the correct answer. A code 33 means High Coolant Temperature but if it does not run then the temp could not be high. ???? Sorry I can not be of more help.
