TC&Z wrote:
Appreciate your suggestion. Our gen gets its fuel directly from the main MH tank. Unclear to me how you want me to introduce the Seafoam into the generator's fuel line. Please provide a bit more info how to do this, apologize its not obvious to me... thx
You can put the Seafoam in the MH fuel tank, I believe they recommend 1oz Seaform per gallon of gas.
Or, you can rig up a small external tank and gravity feed it to the carburetor.
Another option, which I do, get a can of spray Seafoam and spray it into the carburetor while it's running (remove the air filter). Do that a couple times and then stop the generator and leave it sit for an hour or two. This will obviously not clean the fuel line but, it does a good on the carb.
