Gjac
Jun 26, 2014Explorer III
sew0177 wrote:Mine does not slide out either but the fuel pump, carb adjustments, air filter, oil filter are easy to get to. The rear spark plug had to be changed by feeling around to get the socket on. The hardest job was changing the coil witch required a lot of shrouding to be removed to access it.
I dropped my 2000 Pace Arrow off at Cummins Power Central in Kansas City to have my 5500 serviced as it would not start and I did everything I can do. With a $135 labor rate I assume my bill will be about the same or worse.
I would like to ask all of you that have performed your own maintenance ... how in the world do you access the parts? My genset does not slide out and there is only about 2.5 inches from the top of the compartment to the top of the genset. I can feel the sparkplug in the inside but no way I could change it out let alone the fuel pump.
38,771 PostsLatest Activity: Apr 13, 2026
