DrewE
Jul 19, 2015Explorer III
You could also pull the fuse on the generator itself (the little 5A fuse); I think this will disable the controls and prevent the starter solenoid etc. from kicking in.
The generator may well be connected around the disconnect switch as it doesn't generally pose any parasitic loads when it isn't running and because it requires a hefty amount of current when cranking. I know mine is.
The low rumbling you hear—is that the fuel pump in the generator priming the carburetor? That would suggest that a switch is sticking in the "shut off" position rather than the proper "neutral" position.
