loving_retireme's avatar
May 28, 2014
Onan generator only runs with switch held in
Last month my Onan 2800 ran perfectly, today I can't get it to run at all. Here are the details:
(1) Pushing in on the remote start/stop button inside the Roadtrek and also at the access cover at the generator get the same results.
(2) I checked the oil and it is with the recommended level.
(3) Pushing in either switch results in the starter starting the generator gas engine, however the generator stops the moment I release the switch.
(4) Pushing in on either switch and continuing to hold it in result with the generator gas engine to continue to run, but only as long as I hold the switch in.
(5) While holding the start switch in the run position 120VAC never arrives at any electrical outlet.
I am open to any suggestions/ideas of what my Onan problem is.
