Handbasket
May 28, 2014Explorer
You've got a failure to produce AC voltage. It's possibly the voltage regulator, the brushes, or the rotor-stator assembly.
The regulator is in the $250 range for parts (google 'Flight Systems'). It's a doable but dang fiddly DIY repair. There's a hidden Torx screw that's an utter bear to restart, with no lead-in to the hole and no tabs to locate the regulator.
IIRC, the Onan service manual takes you thru troubleshooting steps to isolate what the problem is. You'll need a volt-ohm meter & basic skills.
Jim, "Unapologetic flatulator."
38,779 PostsLatest Activity: Jun 16, 2026
