Roman_Duck
May 28, 2014Explorer
Handbasket wrote:
You've got a failure to produce AC voltage. It's possibly the voltage regulator, the brushes, or the rotor-stator assembly.
The regulator is in the $250 range for parts (google 'Flight Systems'). It's a doable but dang fiddly DIY repair. There's a hidden Torx screw that's an utter bear to restart, with no lead-in to the hole and no tabs to locate the regulator.
IIRC, the Onan service manual takes you thru troubleshooting steps to isolate what the problem is. You'll need a volt-ohm meter & basic skills.
Jim, "Unapologetic flatulator."
Bad voltage regulator, contact flight systems, they will test your old one and confirm the good or bad.
Had same problem, sent it in. Had it tested, found to be bad. order new one. Started right up and stayed running without finger holding.
They do charge for testing, but if it's bad they will waive the test fee and apply the cost towards a new one
38,779 PostsLatest Activity: Jun 16, 2026
