Skiemele
Jul 16, 2013Explorer
Onan Generator Problem Solved
My Onan 5500 Marquis Gold generator would run for about 20 minutes and then quit. I tried replacing the fuel filter without success. I then rigged a gas supply directly to the carb (threaded the old fuel filter into a plastic tank and gravity-fed fuel through a 1/4" hose from a step ladder beside the motor home). Continued to run fine. Apparently, the fuel pump would work until it over-heated and quit.
The fuel pump was an Onan #149-2620. The Airtex E11015 is a direct replacement. I could not find one locally so I ordered from Amazon for about $55. You will need a #30 Torx screwdriver to remove and install.
I also added a fuel shut-off valve before the fuel pump so that I can run the generator dry for storage.
