FIRE_UP
Nov 09, 2015Explorer
chucl66 wrote:
This is a follow up question.
5BGE gas powered (2000 Damon Intruder. Have replaced fuel pump and filter, but still shuts off when switch is released. Oil level is full, battery is fully charged. Full tank fresh fuel. It runs until the switch is released
What suggestions do you have to trouble-shoot for additional solutions to the problem?
Thanks for any help.
Chuck
Chuck,
Wow, does this bring back some OLD, ANCIENT MEMORIES! Let me ask you something here. When you say it runs until the "switch is released",:
1. Are you talking about the start switch/toggle?
2. If so, how long will it run, if you hold on that switch?
3. If it continues to run, as long as you're holding on the switch, I really can't see that it's fuel related but, I'm no expert.
4. If you were to start it, and hold that switch in the start position, (again, assuming it's the START toggle,) and it keeps running, until you let off the switch, I'm going to assume that, for some odd reason, you may be shutting of the spark when letting go of that switch.
I say it brings back ancient memories because, way back a few hundred years ago, GM, Ford and pretty sure Chrysler all had what was called POINTS ignition. (I think some of you "old timers" remember those don't you?). Well, long story short, in most of those POINTS AND CONDENSER operated ignition systems, when you hit the start switch or, turned the key to the start position, you energized the points with a full 12V from the vehicles electrical system.
But, engineers determined that most points, could not operate on the full 12v for very long because it was too much voltage for them so, there was actually 2 systems that fed power to the points. The first was the full 12V that was energized when in the cranking/starting mode. Once the engine caught and was running, you let off the start switch and, that sprung the key back to the "run" position.
In that position, another power system took over the responsibility to feed the coil and the points. But, that system was routed through what's called a "Ballast Resistor". What that resistor did was, step down the voltage to the points to about 8V or so. That kind of lower voltage was more easy on the points and, made them last longer. But, what would happen once in a while, actually more often than most folks knew, was the Ballast resistor would burn out.
When that happened, you would find the EXACT SAME SCENARIO that you're encountering now. The engine would start and run, as long as you kept the key or, start button, in the start position. But, if you let off, the engine would quit. Talk about a bunch of frustration.
Now, I explained all this because, I don't have a clue if your gas generator has anything like that kind of old style starting/running system.
If you keep starting it, and it runs, while holding down the start switch, I'd say you've got enough fuel in the tank. And, I don't know how much fuel that little carb holds but, even if the fuel pump was being shut down due to you letting off the start button/toggle/switch, you should have enough fuel in the carb, to keep it running at least for a short time, maybe a minute or so, or more.
But, it shutting down the micro-second you let off the switch, is what's got me puzzled. Good luck and, please post what you find out is the issue.
Scott
