chucl66's avatar
chucl66
Onan Generator, quits after start.. Update
This is a follow up question.
5BGE gas powered (2000 Damon Intruder. Have replaced fuel pump and filter, but still shuts off when switch is released. Oil level is full, battery is fully charged. Full tank fresh fuel. It runs until the switch is released
What suggestions do you have to trouble-shoot for additional solutions to the problem?
Thanks for any help.
Chuck
  • I had this happen on my 5k Onan. The first thing the generator does when it starts is look for 110v power. If no 11ov found it shuts down. I believe Cummins installed new brushes and cleaned the stator, but it's been a while (2 MH's back) so the stator part might not apply. The genny didn't throw an error code, so it took a diagnostic approach to find it.
    Your situation may be different, just sharing my issue.
  • midnightsadie wrote:
    IF your fuel tank is a quarter down the gen set won,t run.
    Don't you mean if you have less than a quarter tank of fuel the gen won't run? :)
  • Probably needs a new carb, they are about $250 on amazon, the gas with ethanol really screw these carbs up, I now put stabil in every tank.
