- Maw__Jim___JakeExplorerSorry I should have said it is a gasoline generator.
- wolfe10ExplorerWhat generator (gas or diesel) and what problem?
- Matt_ColieExplorer II
Maw, Jim & Jake wrote:
Does anyone know of a good Onan generator repair facility in Richfield UT or Montrose CO?
Thanks
I cannot answer your question directly, but the first thing you need to decide is if it is an engine or a electric end problem.
If it does not start and run, that is and engine problem and an you may have good luck at a small engine shop. The Onan engines are used on lost of applications and chances are that if you look at the right guy, he will at it may already know what the problem is likely to be.
If it runs, but no electricity comes out, call around to electric motor repair places. There may be someone there that is willing to look at it. The problems are usually simple.
Matt - DFordExplorerCheck into the benefits of belonging to Cummins/Onan Power Club - 10% discount on repairs and service. The website says there's one in Grand Junction if that helps. http://www.cumminspowerclub.com/locate.jsp
http://www.cumminspowerclub.com/Cummins/Onan Power Club wrote:
The Cummins Power Club has been developed to better serve our Cummins customers.If you own an RV with a Cummins engine or an Onan Generator, it makes sense to be a club member.As a member you receive a 10 % discount on Cummins Genuine Parts: New, ReCon, Filtration, Onan Parts (Cummins Power Generation Products) and Valvoline products.The discount also applies to service repairs and maintenance on Cummins and Onan products. The discount does not apply to new Cummins engines, Recon engines or generator sets.
The Cummins Power Club is supported by Cummins Distributors throughout the United States and Canada.These distributors are committed to meeting your parts and service requirements.
38,769 PostsLatest Activity: Apr 03, 2026
