bounder39zman
Mar 19, 2014Explorer II
Do you have Onan 10KW with earlier Izusu or later Kubota engine?
usually when gen runs 10 min or so then shuts off with overheat code it
is an air flow issue. I assume you checked water pump/fan belt condition and tightness? Is the Radiator core clean? Also the service access door must be installed or air will not pass thru rad. core and unit will overheat
38,705 PostsLatest Activity: Jan 27, 2025
