Jun 21, 2016Explorer
BobR wrote:
Start by dis-connecting generator fuel line. Mix a gallon of gas with SeaFoam and run generator for 15 minutes from gas can fuel(Have can higher than Genny for gravity feed). Let sit for at least 30 minutes and then restart. It just may be a gunked up carb. Repeat again if necessary. Might have to reset choke. If that doesn't work, then look at other culprits like fuel pump and filter.
Running from a separate fuel source would determine if it's a bad fuel line or a bad pump. If the carburetor were the problem, it wouldn't start and run for 20 minutes.
38,783 PostsLatest Activity: Sep 09, 2026
