roam1
Jul 28, 2016Explorer
BobR wrote:
Start by dis-connecting generator fuel line. Mix a gallon of gas with SeaFoam and run generator for 15 minutes from gas can fuel(Have can higher than Genny for gravity feed). Let sit for at least 30 minutes and then restart. It just may be a gunked up carb. Repeat again if necessary. Might have to reset choke. If that doesn't work, then look at other culprits like fuel pump and filter.
what do you mean or how do you reset choke?
I ask because I had similar problem as the OP, same solution, but my choke has not worked since. It starts fine, runs rough for a few minures, then runs fine.
sounds to me like faulty choke
38,783 PostsLatest Activity: Sep 09, 2026
